Author Topic: [Questions]FPS Rate Minimization/X Bone Movement  (Read 12102 times)
NeonFalcon
  • ill stay in touch:)made on pivot
« on: September 08, 2009, 03:48:56 am »
Hello everyone. I have 2 questions I want to ask. Which are :
1. How do I reduce the fps rate in each frame while in sequence mode? It's normally 64 fps I want it down to 7 fps. How can I modify that?
2. I have a figure Kreator rigged for me. It's awesome but the only problem is that it only allows me to move the bones in x-directions. Each x,y,z bones have no limit and still it won't allow me to. How can I fix that?
Thank u for your concerne and I hope for some quick replies. :D
Re: [Questions]FPS Rate Minimization/X Bone Movement
« Reply #1 on: September 08, 2009, 04:13:17 am »
Go to View > Preferences and change to Other 7
X = left mouse button
Y = right mouse button
Z = middle button
Read the manual
« Reply #2 on: September 08, 2009, 05:15:40 am »
Go to View > Preferences and change to Other 7...
And make sure the "Limit Playback" checkbox is checked.
« Reply #3 on: September 08, 2009, 06:28:34 am »
Nicely caught Kubajzz :D
« Reply #4 on: September 08, 2009, 02:49:44 pm »
Z = middle button
Read the manual
Also, you will find that they will still do not move in certain views, so try all views before you go "Gung Ho" with The buttons
( I don`t normally set "No limits" to every bone as in true life some of the contortions you can get are not possible,but it was quicker to set them all so)
