Author Topic: LODs  (Read 9795 times)
runter
    • Code Vikings Entertainment
LODs
« on: August 31, 2009, 09:17:35 am »
Hello everyone,
I was wondering if there is a way to generate LOD meshes from an original an8 file.
Thanks!
runter
Re: LODs
« Reply #1 on: September 03, 2009, 06:27:04 am »
It seems I am an expert in asking questions nobody knows...  ;D
Jehovahenker
Re: LODs
« Reply #2 on: September 03, 2009, 08:47:34 am »
whats LODs? :P
Re: LODs
« Reply #3 on: September 03, 2009, 09:08:49 am »
Sorry mate, no idea.  Anim8or can output meshes in a couple of formats, and there are plenty of free format converters available online.  I can only suggest doing a bit of web research and finding the right converter(s).  What is the LOD format used for?
Claude
Re: LODs
« Reply #4 on: September 03, 2009, 10:05:07 am »
LOD level of detail
copies of the same model made with lower number of triangle
mainly used in game to increase rendering speed
close to the camera:high LOD
far: lower LOD
Terranim8or has a decimator.It might help.
Claude
Re: LODs
« Reply #5 on: September 03, 2009, 10:29:20 am »
There's also a script:
Poly Reducer (Reduce Triangles)
Reduces a triangulated mesh anywhere between 1%-95% while preserving materials and UV Coords.
Author: Kubajzz
See the script section of the forum for a link :first post .
« Last Edit: September 03, 2009, 10:30:55 am by Claude »
xalener
Re: LODs
« Reply #6 on: September 06, 2009, 06:52:05 pm »
You could select the whole model and use "merge points" to lower the polycount.
Just make the threshold higher than usual.
