Author Topic: Trying to animate water  (Read 7210 times)
Bobert
« on: August 02, 2009, 04:54:03 pm »
So I've tried using Terranim8or to animate water and everything turned out fine..almost.
The only problem I have is that the water has to be animated for a long scene. As a result terranim8or created ALOT of objects for the water morphing sequence.
Is there anyway to animate water without generating so many objects? Is it possible maybe to use one object (the water) instead of multiple ones?
Re: Trying to animate water
« Reply #1 on: August 03, 2009, 03:46:42 am »
what exactly is the water doing?
there is watergen which works very well as long as uyour read the destructions and stay away from the bones - some say it is buggy and unstable - which it is ;)
to animate waves I did okay with extruded sp[lines that are mafde into morph targets with morph envy
morphenvy works very well if the destructions are followed. keep ypur names at object01 and object 02 etc.
you could alos use the perlin plugi in with variations on the noise parameter on the same mesh then use morph envy
« Reply #2 on: August 03, 2009, 03:56:09 am »
notreallya zip just change the extension to exe (not zip)
« Reply #3 on: August 03, 2009, 03:58:36 am »
here is t'other
very difficukt to get
