Author Topic: How Do I Use Point Editor  (Read 7388 times)
GeniusAtWork
« on: February 13, 2008, 06:57:01 pm »
I dont know how to use point editor. my object is mesh and selected and i am in point edit mode but i can;t do things like shell and take the edges off. and also im wondering how you can make your anim8tor work smaller so you can upload it to share it. ::)
Re: How Do I Use Point Editor
« Reply #1 on: February 13, 2008, 07:30:39 pm »
Don't upload directly to this site.  The uploading limit is pretty small, and I can't even put reasonably sized images up.  So if I were you I'd go to a site such as savefile.com and upload the anim8or file, or a .zip file with the anim8or file in it.
As for point editor, one of the biggest things that will help you is to read the manual and experiment with ALL the tools.  If you haven't read the manual yet, the is the FIRST thing you should do.  I STRONGLY advise it.  If you've done that, try following tutorials, they'll teach you step by step how to use the point edit mode.
GeniusAtWork
« Reply #2 on: February 13, 2008, 07:43:51 pm »
I have tryed the manual but will have another look at it. I will try some tutorials. Thanks for your help ;D
Frankie
« Reply #3 on: February 16, 2008, 11:19:54 am »
 The manual is amazingly helpful.
