Author Topic: Testing Textures  (Read 8007 times)
Navek
Testing Textures
« on: July 10, 2009, 08:16:50 pm »
Just posting a test render of something I'm working on. If you guys have any tips on making realistic textures could you please post them?
Ps, I'll put the final pics here when there done.
lizeal93
  • Coool!
Re: Testing Textures
« Reply #1 on: July 15, 2009, 05:48:24 pm »
cool!
is that a forrunner structure from Halo?
anyways the only issue that i am noticing is that texture seams. these can be easily eliminated in the gimp by applying a filter->map->make seamless. and that shoyuld give you a seamless texture.
cheers!
-Albert Einstien
falloffalot
« Reply #2 on: July 16, 2009, 03:02:48 pm »
Nice work.
When you texture multiple objects of the same shape ensure the textures don't match.
If you use Photoshop to make your textures simply add some extra dirt, scratches or crack layers and use the "save as". This will save you from making a new texture each time.
As lizeal, the 1st pic texture needs to be tiled with seamless joins, also rust is very irregular and none uniform. If you have a look at my mine cart there is a good example of poor seaming on the rails.
(Oh nuts...I’ve just given away the answer to my question on that thread).
Navek
« Reply #3 on: July 16, 2009, 05:06:54 pm »
Thanks for the tips guys. I'm trying them right now and i'll update this when I'm finished.
