Author Topic: Texture mapping a planet with Photoshop  (Read 20643 times)
Pincho
« on: June 27, 2009, 04:37:46 pm »
I need a tutorial on how to texture a planet without the ends squashing up.
Thanks!
siragin
    • Shatalu Productions
Re: Texture mapping a planet with Photoshop
« Reply #1 on: June 27, 2009, 11:30:36 pm »
Do a google search for planet textures) get a flat map texture . create a speare add material
Pincho
« Reply #2 on: June 28, 2009, 12:01:56 pm »
I am creating Alien Planets for a computer game, I will not be able to find a texture that is already made. I need to figure out how to bend my image to the right shape to fit a sphere.
« Reply #3 on: June 28, 2009, 03:34:22 pm »
First find a suitable texture of planet earth, put it on a sphere to check if it works.
If it does open earth in photoshop, add a new layer and paint your new planet to match the underlying earth. That should work.
« Reply #4 on: June 28, 2009, 07:26:00 pm »
Check out this tutorial I made for you HERE
Pincho
« Reply #5 on: June 29, 2009, 02:42:28 pm »
Thanks, but you didn't show me how you made the texture. But I have now found a Photoshop Filter that automatically fixes textures so that they will wrap around a sphere.
http://www.richardrosenman.com/media/software/files/spheremap.zip
« Reply #6 on: June 30, 2009, 04:02:07 am »
You wanted to be shown how to use Photoshop???
Really the texture is just a 1024 x 1024 jpg  nothing more than that,
Anim8or will map it onto the sphere for you using the uvmapper tool.
Pincho
« Reply #7 on: June 30, 2009, 09:21:22 am »
Well you need spherical mapping correction when used for Sphere's, and you need to make a special texture usually so that the ends are not pinched. Even if Anim8or does automatically fix the texture, I don't know if Anim8or can export the fixed texture afterwards. But being as I need the planet for a game, I need the texture, and planet exported separately.
« Last Edit: June 30, 2009, 09:28:57 am by Pincho »
