Author Topic: how to make ground?  (Read 6182 times)
personak
how to make ground?
« on: May 15, 2009, 06:43:18 pm »
I am trying to make a ground for my animation. I could use some direction.
Re: how to make ground?
« Reply #1 on: May 16, 2009, 04:28:42 am »
make a flat plane.
if you make a cube and convert it to mesh.(select cube build > convert to mesh) you can go into point edit mode and delete the bottom (or top) points and you will have a flat plane. if you want to make hills and valleys. select the face and go to edit > subdivide faces. do that as many times as needed. you can do the same thing a few different ways but thats how i usually do it.
there is a program called terranim8or. it pretty much does that for u automatically. i think it randomizes your hills and valleys for you. i didnt really mess with that program much.
good luck
« Reply #2 on: May 16, 2009, 10:35:05 am »
hi personak :)
i attach the twos scripts to maker planes
make download and insert in your folder of "script" ok
att.
personak
« Reply #3 on: May 16, 2009, 11:48:28 am »
thanks on both
