Author Topic: Change texture of an object at diffrent frames in a scene?  (Read 6527 times)
pixidou
    • Pixidou Anim8ion
Hi,
I want to use texture for lip sync in my model. My problem is i have to change the texture frame by frame and then render it to image (i can't render to movie). Is there a way or any script to change the texture of an object dynamically.
thnx for your help...
Re: Change texture of an object at diffrent frames in a scene?
« Reply #1 on: May 05, 2009, 06:47:18 am »
Unfortunately this is not currently possible within Anim8or, at least not directly.  There are, however, a couple of alternatives.  For example, creating a series of faces or heads each with different textured expressions, and animating them with the visibility function, would be a possibility.  I believe Terranim8or (available under the Resources link at left) is capable of animated textures, and is well worth downloading for this feature, among others.
pixidou
    • Pixidou Anim8ion
« Reply #2 on: May 05, 2009, 07:11:46 am »
thnx ensoniq5,
got u clearly,
