Author Topic: help with door  (Read 15686 times)
kalanis_lz
help with door
« on: February 06, 2008, 11:53:18 pm »
i'm having trouble with the rear door of this avenger every time i try to fix the problem it looks worse does anyone have any tips to modeling this door
Re: help with door
« Reply #1 on: February 07, 2008, 01:00:18 am »
Could you give a transparent wireframe view with the reference in the back?  That way I could draw over your model much easier for you to help with the edge looping.
kalanis_lz
Re: help with door
« Reply #2 on: February 07, 2008, 11:42:41 am »
i hope that this helps
Re: help with door
« Reply #3 on: February 07, 2008, 05:43:39 pm »
Here's a draw-over I did for you.  I simplified the mesh a lot, because as long as you're subdividing it doesn't have to be overly-detailed, though you also don't want to get underly detailed.  I may have missed a loop or two, but this should give you the flow you're looking for in your model.  I hope this helps!  :)
vobla
Re: help with door
« Reply #4 on: February 07, 2008, 09:24:02 pm »
Emm.. Dont be afraid to delete points you dont need and fill holes after adding nececary lines.. ;)
kalanis_lz
Re: help with door
« Reply #5 on: February 07, 2008, 10:40:52 pm »
one more quick question where the back of the door meets the wheel well the angle of your lines are coming from a central piont would it still give that beat up look by interupting that line? ok another question i see how all the lines are positioned from the wheel well, but where my pink line is how would i get this to free form into that flare of the well?
Re: help with door
« Reply #6 on: February 08, 2008, 01:02:34 am »
Ah, I didn't realize that's where the door ended.  A lot of this is simple, you can just move points around.  So don't necessarily stick exactly to what I drew, you can rearrange points afterwards, and of course add extra loops.  If you look at the way the edges flow, you can insert new lines of edges with the cut tool that flow as well.  I hope this helps a bit ;)
kalanis_lz
Re: help with door
« Reply #7 on: February 09, 2008, 01:03:00 am »
yes that helped alot i got that rear door finished and now i'm moving to the front quarter panel i'll continue my progress on this topic
kalanis_lz
Re: help with door
« Reply #8 on: February 09, 2008, 12:37:37 pm »
heres the dodge avenger strom trooper edition with the corrected rear doors (thanx hihosilver) and the front quarter panel and hood
« Last Edit: February 09, 2008, 12:39:53 pm by kalanis_lz »
