Author Topic: new stuff  (Read 7643 times)
new stuff
« on: May 02, 2009, 07:29:46 pm »
im not sure if this is the right part of the forum or not, but theres a few things that would be helpfull. I hope you consider some of these. thanks
you can double click on a single point in point edit mode and set ur cordinates. it would b very usefull to use the drag and select tool and set your cords for all of the selected points. (its a bitch doing it one by one by one).
i think being able to hide certain sections of your model in point edit mode would be extremely helpful. its hard to figure out which point you need when theres a million things going on behind it.
the slider tool is very usefull. the only problem is u can only slide one point at a time. being able to slide a bunch of points at once would be awesome.
being able to color your lines in wireframe mode. i think you would be able to see things more clearly and you can see the depth alot better. it gets confusing in between your loops when your making creases and notches and whatnot.
