Author Topic: 5 Window Coupe  (Read 11575 times)
Ratticis
  • NOW WITH 90% MORE AWESOME!
5 Window Coupe
« on: April 26, 2009, 08:34:19 pm »
My first attempt at modeling
Re: 5 Window Coupe
« Reply #1 on: April 27, 2009, 07:17:24 am »
That's really good, you got the hang of it :)
TomiL
  • Keep on rollin´
Re: 5 Window Coupe
« Reply #2 on: April 28, 2009, 02:30:18 pm »
Very good for a first try. I would make it a tad wider ;)
Put some few details into it and render it using Art.
| Finnish Anim8or user |
WIP:
MP3 Player
TomiL´s stuff
Ratticis
Re: 5 Window Coupe
« Reply #3 on: April 28, 2009, 04:33:33 pm »
Thanks for the feedback. I was going to keep going and add some more detail, but I decided that I would probably be better off to start over using what I had learned on this one to create something better. It probably took me about 2-3 hours but I really learned a lot and could probably do it again in about 20 mins :P
Arik_the_Red
  • Just another aninoob...
    • æwakened!
Re: 5 Window Coupe
« Reply #4 on: April 29, 2009, 10:30:58 am »
Learning by trying is the real trick in this program... This is a good little "first ever" model.
I know that every time I start something I learn some new technique just by experimenting, and then end up many times starting over and making something a little better than the previous attempt.
I look forward to seeing your rework, because I think it'd be cool to compare it with the first, and make for a more meaningful display of "see what I learned?"
Ratticis
Re: 5 Window Coupe
« Reply #5 on: April 30, 2009, 10:07:53 pm »
Re: 5 Window Coupe
« Reply #6 on: May 01, 2009, 03:05:54 am »
Well, the roads looking more defined now from the rest of the land, although I'd suggest you scale down the texture or using a higher quality texture, this will get rid of the pixilation for you.
But, this is very good for a first model!
Ratticis
Re: 5 Window Coupe
« Reply #7 on: May 01, 2009, 04:52:02 pm »
Ya, I just took 4 seconds yesterday (Plus the 10 minutes waiting for it to render :P) and changed the material on the wheels and rad support to chrome and re-rendered it using ART
