Author Topic: Some one can help me?  (Read 21125 times)
wiljcrow
« on: February 05, 2008, 04:07:16 pm »
Hello I'm new here and in anim8or, well I have problem with script, I take the script to export file for game maker (in format .gml) but I don't find when I want to export the file is just .obj - .vtx - .c
Maybe I wrong something?
Please help me, thank in advance
vobla
Re: Some one can help me?
« Reply #1 on: February 05, 2008, 05:44:35 pm »
Wel I havent been using any export scripts on Anim8or, but I think you just need to click on File->Configure.. than set script directory which should contain your export script, then restart Anim8or, open your model, Object->Export.. and choose the Save As Type you need ;)
Cheers ;)
wiljcrow
« Reply #2 on: February 06, 2008, 03:22:57 am »
Thanks for answer my post, but I do that, and I don't find the extention, maybe the script is not correct?
vobla
« Reply #3 on: February 06, 2008, 08:49:50 am »
Hmm.. First think you can try is taking a look at the console window. Just check if all the scripts are compiled with no errors.. Try download the script again..
« Reply #4 on: February 06, 2008, 06:59:29 pm »
Is the .gml script in your "Scripts" directory?  (See the File->Configure dialog to set this.)  If not then it won't load and won't show up in the export list.
Claude
« Reply #5 on: February 06, 2008, 08:33:12 pm »
Also make sure the "Preload Scripts" box is checked.
