Author Topic: DivX codec dose work :(  (Read 9465 times)
TheLose32
« on: April 25, 2009, 04:28:11 pm »
Hey guys! i have made an awsome animation on anim8or and when i make an movie i click [ok] and the window pops up with codecs.. i only have 1 codec and its the bad default one  :-[ i have DivX installed an codec too... i use anim8or 0.95c... plzz... how can i get DivX codec work on anim8or ???  i realy want have my awsome animation done  :'(
[Edit] i have DivX version: 7
« Last Edit: April 25, 2009, 07:07:12 pm by TheLose32 »
Re: DivX codec dose work :(
« Reply #1 on: April 25, 2009, 05:27:33 pm »
Hey,
I don't know why anim8or is doing that for you, or how to fix it.
I can give you a tip though. You can save all the images of an animation as image files, and then use a program like Virtual Dub (http://www.virtualdub.org/ , its free!) to compile it into a video. You have much better control over all the settings & you can change the individual frames before making it into a video.
So thats what i would suggest at this moment..
TheLose32
« Reply #2 on: April 25, 2009, 06:32:34 pm »
Hey,
Thanks!!!! but the quality is bad on the images... i put 100  :-\  see for ur self.. i wanna that Anim8or program quality  ;D
Anim8or program quality:
Image quality set at: 100 JPEG:
its not good... cuz i wanna use that for my youtube presentation  :-\ and i need that white think in the O it must be white and not gray :'( in image it more darker  :-\ can i fix it? other ppls... try answer my first post
« Reply #3 on: April 25, 2009, 09:44:49 pm »
I wouldn't be so be quick to judge Anim8or, TheLose32.  Looks to me like you need to make some adjustments to your materials settings and it definitely could use more lighting.  For instance, you could make the white material emissive.  You could also use some anti-aliasing.
TheLose32
« Reply #4 on: April 26, 2009, 04:04:58 am »
My Problem is i dont have NO 1 codec on anim8or... i have alot codecs installed like DivX,Xvid, Xfire codec.... but it dont shows up on anim8or  :-\ But Thanks :D im not so much into english :LOL:
« Reply #5 on: April 26, 2009, 06:26:04 am »
Try downloading this codec pack: K-lite codec pack.
It's holds most of the common codecs and is free to use. Not only helpfull with rendering but also with playing videos.
If still nothing shows up in anim8or, try downloading the anim8or.exe once again.
jacko
« Reply #6 on: May 05, 2009, 11:28:50 am »
http://www.anim8or.com/ubb/Forum1/HTML/013089.html
