Author Topic: Help  (Read 8597 times)
kwatie
Help
« on: March 24, 2009, 02:35:53 am »
I'm having trouble im making something but i need to rotate some faces the same way: up but when i try to do that they all go in differnt directions can someone please help
Re: Help
« Reply #1 on: March 24, 2009, 06:15:51 am »
Hello kwatie, welcome to the forum!
About your problem, it is a bit difficult to understand what you are trying to say. Can you maybe give some more details or a screenshot of what you are trying to do?
- are you selecting individual faces and then using the Rotate Faces Tool ? Or are you selecting several different objects and rotating them with the regular rotate tool?
If you are rotating different objects, try selecting each object seperate and going to Build > Join Solids, this will reset the Pivot Point of the objects, so that they rotate around their center.
Good luck!
kwatie
Re: Help
« Reply #2 on: March 25, 2009, 01:19:16 am »
im selecting several faces and then using Rotate Faces tool and when 1 goes up 2 face in ward, 2 face outward and 1 face downward i will try joining the solids though
Re: Help
« Reply #3 on: March 25, 2009, 06:17:08 am »
Try this, select the faces you want, hit 't' which will select all the faces edges. Then use the rotate tool (not the rotate face).
kwatie
Re: Help
« Reply #4 on: March 26, 2009, 04:43:03 am »
Same effect sorta, they dont turn upwards at the same angle
Aeth
Re: Help
« Reply #5 on: March 26, 2009, 07:58:18 am »
well, try activating grid snap and doing each one seperately. snap should help keep them lined up.
