Author Topic: malformed spline  (Read 13645 times)
mak
malformed spline
« on: March 18, 2009, 07:31:33 pm »
just a cuirous question to increese my anim8tion knowleage ( kneed to increese my spell knwlage to)
im sitting here doodling with splines, i made a spiral but if i try to extrude it i get "malformed spline cant extrude" i have come across this before. im curious why.
realisim is for reality
rctmonger1108
Re: malformed spline
« Reply #1 on: March 19, 2009, 05:05:21 pm »
post a screenshot of ur spline and i'll see if i can help.
Trying to do too many things at once: game design, programming, 3D modelling & animation, and graphic design.
http://johnsongames.110mb.com
http:///johnsongames.lefora.com
mak
« Reply #2 on: March 19, 2009, 11:56:11 pm »
its not a project or anything, im just trying to understand splines a little more
rctmonger1108
« Reply #3 on: March 20, 2009, 03:50:12 pm »
you need to close the spline for it to extrude, i believe.
onespirit5777
« Reply #4 on: March 21, 2009, 01:18:11 pm »
Learn to draw in the Object/Point Edit mode, you will thank yourself later - Trust me!
It's the button with the 3 little squares under the eye.
I don't know how new you are to the program - Sorry if it sounds funny - Well I guess it does sound a little goofy. LOL!
I'm not miss leading you - Then you go to another button with three squares but two of them are connected - This is the Add Edge button - Before you start to draw you must hold down the shift key to draw your first line.
mak
« Reply #5 on: March 21, 2009, 03:40:26 pm »
ive been using anim8or for about 6 or 7 years now. i know it says newbie under my name but i think thats based on the amount of post not time. i guess to be more specific to my question,  what constitutes a malformed spline, i just wish to understand what it is about this shape that prohibits extruding.
« Reply #6 on: March 27, 2009, 06:31:11 pm »
This problem still stumps me.  I was able to extrude a spiral object when I had a zig-zag forming in the middle (though only with every other zig-zag.  for examples, when there were 2, 4 and 6 spline edges crossing the distance from the start point to the end point, it was a malformed spline.  Then, when I had the zig-zag and there was 3, 5, and 7 edges in-between it extruded.  Yet then it didn't seem to work when I did this with curved splines, and I found it was the opposite (2, 4, and 6 switched with 3, 5, and 7.)
Now I find that it doesn't work with more than one loop of the spiral though... so I'm still stumped.
Reading this over I'm completely sure I've confused everyone here, but don't worry, I'm as confused as you are.
« Reply #7 on: March 28, 2009, 05:19:17 am »
Have you tried drawing your spline in a view other than Front ?
I tried to replicate your spline and in Front view I also get the error message of malformed spline, however, in side view it extrudes perfectly.
Maybe a quirk of the program ;)
mak
« Reply #8 on: March 29, 2009, 12:34:07 am »
your right, and in all three axis, i wonder why that would make a differnce
