Author Topic: How do i make a render image with the same colors as on the screen?  (Read 6503 times)
Matinas
Normally I have no problem on render image but now it gets all messed up. The one on the right is a screen shot and one on the left is the render....what am I doing wrong?
Re: How do i make a render image with the same colors as on the screen?
« Reply #1 on: March 11, 2009, 04:01:43 pm »
The answer is simple: you're not doing anything wrong...
A rendered image usually looks differently than what you can see in the editor. The reason why this happens is simple:
The Anim8or GUI uses a "simple" and fast way to display shapes and colors to allow real-time operations. Once you render an image, the program uses much more accurate (and more complex) shading methods and that's why a rendered image is usually a little different.
here's a little advice: When you're creating a material, always make a test render to see what it "really" looks like and don't worry if you see something weird in the editor.
