Author Topic: Speed  (Read 8102 times)
Conker303
Speed
« on: February 24, 2009, 08:20:40 am »
I go to create just a simple ball scene but when I click play the scene moves a lot faster than the three seconds. Why does it moves so fast and also how do I make it to were I have more frames than just 3 seconds. Please reply.
Monex
    • My homepage (not done)
Re: Speed
« Reply #1 on: February 24, 2009, 08:47:41 am »
You can change the frame rate in: view -> Preferences (Bottom)
RudySchneider
Re: Speed
« Reply #2 on: February 24, 2009, 10:05:20 am »
And as far as how many frames you have, click on Settings > Scene..., and enter the number of frames you want in "Length."  The Scene Editor only shows 72 frames at a time, but you can "slide" the time-line by double-clicking on it and and then pressing the left- or right-arrow key.
G
Re: Speed
« Reply #3 on: February 24, 2009, 01:05:09 pm »
The issue may be that you didn't limit the playback.  To do this, go "view>preferences" and check the limit playback box.  It is possible for it to run slower (if there are too many poly in the scene for the computer to handle), but it will limit it so that it doesn't run too fast as you say it is.
Conker303
Re: Speed
« Reply #4 on: February 24, 2009, 06:58:44 pm »
Thanks you guys really helped me.
xalener
Re: Speed
« Reply #5 on: February 25, 2009, 11:44:46 pm »
You could hold the right arrow key down.
