Author Topic: Grunge Mapping  (Read 8358 times)
Maxfield
Grunge Mapping
« on: February 17, 2009, 09:35:56 am »
I don't know if anybody's tried this before, but here goes. I got a couple of metal textures, and a bumpmap. Now, normal Anim8or procedure is to have the same texture in the diffuse and ambient channels, but I tried something else.
I put the bump map into the ambient channel and set it to -1. In the "Textures" section of the material editor, I set the ambient to "Lighten". Next I press the little "divorce" button that unhooks the ambient from the diffuse, and set the ambient color to black.
I put the texture map into the diffuse channel and set it to 2.
Behold - the bumpmap acts as a dirt or grunge map.
I've experimented with putting the bumpmap into the specular channel, and/or setting the diffuse channel to "Darken". You get subtly different effects.
Note - in Scene mode, increasing the ambient light in the scene makes it DARKER when you use negative ambient materials. Also, it can flip the colors into negative as well, so it works best with greyscale maps.
There's two renders here, one grunged, the other with the "vanilla" settings that you get with the material editor.
« Last Edit: February 17, 2009, 09:46:48 am by Maxfield »
xalener
Re: Grunge Mapping
« Reply #1 on: February 18, 2009, 05:14:23 pm »
Sweet!
Dreadkb
Re: Grunge Mapping
« Reply #2 on: February 18, 2009, 07:10:10 pm »
A very interesting technique you have there. I'm going to start trying this out as soon as I'm back from vacation.
Project Test Chamber
    • We Own the Skies
Re: Grunge Mapping
« Reply #3 on: February 22, 2009, 04:06:15 pm »
This works really well, just tried it out, nice one!
http://www.weowntheskies.co.uk
Main Website for We Own the Skies film project previously known as Project Test Chamber 19 :)
