Author Topic: Script Request: Flatten line?  (Read 13580 times)
Suppastar
« on: February 13, 2009, 12:46:59 am »
Can anyone make a script that acts like "flatten" command, but works with just lines?
I have a hard time fixing all the lines that were made crooked or wrong, just wondering if anyone could make a script that could do this for me?
Re: Script Request: Flatten line?
« Reply #1 on: February 13, 2009, 01:34:52 am »
You could just merge points...
Suppastar
« Reply #2 on: February 13, 2009, 01:47:34 am »
Sorry, that's not what I'm talking about, I'm talking about this...
Selecting the Messed up/Crooked Lines, and using "Flatten Lines", flattens them into image #2.
The same effect as the original "Flatten" does , but that only works on faces, not lines.
« Last Edit: February 13, 2009, 03:45:52 pm by Suppastar »
« Reply #3 on: February 13, 2009, 02:34:36 am »
I agree, it would be a nice script, though there would have to be two, one vertical and one horizontal (could it be view dependent? or would it have to be axis dependent?)
« Reply #4 on: February 13, 2009, 08:53:29 am »
Hi Suppastar, :)
see this script in link:
http://www.anim8or.com/cgi-bin/postings.cgi?action=reply&forum=ASL+Scripts&number=6&topic=000032.cgi&TopicSubject=Snap+to+point+script&replyto=8
or direct download:
http://homepage.ntlworld.com/w.watson3/main/files/Snap2Pnt.zip
this script work like you want, in Axis Y...!
but if modifiqued the code, work full in axis Y and X... :)
[]s
« Last Edit: February 13, 2009, 08:55:38 am by neirao »
Monex
    • My homepage (not done)
« Reply #5 on: February 13, 2009, 09:05:18 am »
I was just wondering, if you could use the two points at the end, to make a strait line to align the points and could do it in 3d :)
Suppastar
« Reply #6 on: February 13, 2009, 12:59:17 pm »
Thanks everyone
@Neirao
Thanks for that script, but that was for snapping points together, not straightening out the lines.
Basically as I said, we just need a script that acts like the original Flatten command in anim8or, but works with lines and points also. I can't tell you after hours and hours of point modeling, some of the lines are at a slight angle.  Which on some models can ruin the look, if we had script that could make sure the lines are straight it would make modeling a lot easier.
This is script that I think everyone would use, maybe Steve could implement a version of it with command prompt like the original flatten command, or even work it into the original some how?
« Last Edit: February 13, 2009, 03:48:22 pm by Suppastar »
Claude
« Reply #7 on: February 13, 2009, 10:17:17 pm »
« Reply #8 on: February 16, 2009, 07:55:14 am »
@ Suppastar:
the script work... but for not "join" all the points, we have then unselect the axis then not want mover the points..in , please try again OK  ;)
@Claude: thanks!
