Author Topic: Anim8or Crash  (Read 15141 times)
AirAKose
  • Anime Artist Wanna-be
    • Tratane
Anim8or Crash
« on: February 08, 2009, 01:45:23 pm »
Hello!  :D
I'm working on a little optical illusion clip for Valentine's day next weekend... I have everything modeled, textured, and animated in scene mode... But when I go to render anim8or crashes...
I'm scan-lining the animation renders because ART Ray Tracer makes my animation too dark...
Also, I'm running Windows XP.
Any idea what is wrong?
EDIT: Here are the pictures I could render from the animation-
(Here is just one of the models I'm using)
(Here is a render from the scene before it crashes)
« Last Edit: February 08, 2009, 01:48:47 pm by AirAKose »
Re: Anim8or Crash
« Reply #1 on: February 08, 2009, 02:12:53 pm »
Could you post the file, then we could check if crashes on other computers too. So if the problem is the files or your computer.
AirAKose
    • Tratane
Re: Anim8or Crash
« Reply #2 on: February 08, 2009, 04:15:44 pm »
Ok, here is the file ^^' Idk how anim8or files work... so let me know if I need to include the textures too, please ^^'
Re: Anim8or Crash
« Reply #3 on: February 08, 2009, 04:56:09 pm »
Nothing seems wrong to it. I tried rendering it with scanline and ART and it worked fine, no crashed. Maybe add the textures to (make a zip file of it would be the best), and then i will try again.
AirAKose
    • Tratane
Re: Anim8or Crash
« Reply #4 on: February 08, 2009, 05:05:06 pm »
Textures attached ^^' I'm thinking that maybe the textures are too big or something?... But idk, my computer isn't the best.
Re: Anim8or Crash
« Reply #5 on: February 08, 2009, 06:18:16 pm »
Well yet again no errors here. I think it's your computer then. I rendered the file for you, if that helps...
Render 1 is scanline and 2 is ART (which is indeed pretty dark).
xalener
Re: Anim8or Crash
« Reply #6 on: February 08, 2009, 06:22:25 pm »
Are shadows on that sphere? Maybe that's why ART's so dark.
Re: Anim8or Crash
« Reply #7 on: February 08, 2009, 06:25:41 pm »
yes that's right. All objects in ART cast shadows by default so the sphere makes the scene so darker. You can fix this by removing the frond of the sphere (the part that isn;t showing on the render).
AirAKose
    • Tratane
Re: Anim8or Crash
« Reply #8 on: February 08, 2009, 08:31:15 pm »
Well thanks ^^' I guess I just need a better comp then... For now, lets see if it will let me render individual frames without trouble ^^'
Boywonda1
Re: Anim8or Crash
« Reply #9 on: February 24, 2009, 09:27:07 am »
I don't know about getting a better comp cause my P.C was doing the same;i run on  vista, just try extracting anim8or again (if you have the zip file) seems to work for me :)
Re: Anim8or Crash
« Reply #10 on: March 03, 2009, 01:46:21 am »
The reason it's so dark using ART is that the tranparent spheres cast shadows.  ART can't handle shadow rays through transparent surfaces.
