Author Topic: where can i find a free uv mapper?  (Read 17140 times)
im not a people person73
  • P.I.E
    • my NG
« on: January 26, 2008, 11:35:01 am »
I tried terranim8or but the uv mapper seems to only work on terrain I create with it. I'm looking for something like the tutorial using paint shop pro but I'm on the titest budget. :'($0.00
Gween123 is also me (NEWGROUNDS)
Re: where can i find a free uv mapper?
« Reply #1 on: January 26, 2008, 12:18:36 pm »
http://animanon.xtreemhost.com/index.php?board=36.0
roadkill and UVmapper classic at this link
  • P.I.E
    • my NG
« Reply #2 on: January 26, 2008, 12:30:06 pm »
I'm using uv mapper classic right now but i cant use my anim8or models.Why?
  • P.I.E
    • my NG
« Reply #3 on: January 26, 2008, 12:39:09 pm »
I'm using roadkill now and it has the same prob.
« Reply #4 on: January 26, 2008, 12:58:36 pm »
convert thenm to 3ds or obj format with anim8or ... I think UV classic is Obj format offhand
just save as Obj format instead of An8
you won`t be able to import straight anim8or objects they must be converted to Obj format
« Last Edit: January 26, 2008, 01:00:50 pm by kreator »
  • P.I.E
    • my NG
« Reply #5 on: January 27, 2008, 04:28:47 pm »
it is in that format but i can't open it.i'm confused! ???
« Last Edit: January 27, 2008, 04:37:55 pm by im not a people person73 »
  • P.I.E
    • my NG
« Reply #6 on: January 27, 2008, 06:28:02 pm »
ok i got it but how do you texture it.(all i can find is selection tools
« Reply #7 on: January 28, 2008, 11:55:13 am »
You will need to separate all the meshes in UVmapper then apply a new map to each one ... There used to be a tutorial on the old anim8or.org site done by Bravo One but it is not available any longer ( unless it was uploaded here way back) I do have a copy of that on paper,and I will see what I can do to help you out.
« Reply #8 on: January 28, 2008, 01:24:45 pm »
load in the obj ....go edit ...select all press / three times to reduce size.
now go edit...colour...colour by gruop
then again edit....select....select by group
u should now have selection for the meshes
select your first mesh ...  then drag from selection box up to middle of screen, u can press * on keypad to make bigger / smaller
once it looks good  go select...New Umap ....planar( or whatever) u might have to play with all the settings to get each mesh right...
repeat for all other meshes once you have done all the meshes go File...save model... ok the box then save the model like modelmapped.obj  so you know its a mapped model,
 then file...save texture map
save the map as something that relates to the model
now use the texture mapped file in gimp, photoshop etc ...
overlap each mesh by a couple of pixels otherwise u get white area on outline
reload into anim8or as obj model  then usr your texture as material
Hope this helps.
I will try and do a better version ... which u will find later on Animanon
  • P.I.E
    • my NG
« Reply #9 on: January 28, 2008, 04:12:26 pm »
thanks
rounder
« Reply #10 on: February 02, 2008, 09:39:44 am »
Here is a tutorial I did some years ago for using uvmapper and anim8or with dark basic.  Skip the dark basic parts in the beginning/end, enjoy!
http://biederman.net/joe/tutorials/dbmap/dpmap1.htm
shirine
« Reply #11 on: February 07, 2008, 06:19:45 am »
Hi,
I found this one, thought it might be of use....
http://quick-help.net/uv-mapper
