Author Topic: multi point slider  (Read 20914 times)
multi point slider
« on: January 30, 2009, 12:38:03 am »
is there 1? can some1 make 1? i think it would b very usefull. especially for makeing ur loops.
Re: multi point slider
« Reply #1 on: January 30, 2009, 02:47:58 am »
Can you elaborate? I'm confused at what you mean.
« Reply #2 on: January 30, 2009, 03:04:37 am »
the slide tool. S is hotkey. u click on your edge point and it slides along the line instead of pulling away from the mesh (the move tool). i was wondering if u could select multiple edge points at once like the drag select tool but with the slide tool. ive found myself wanting to move a bunch of points just a little bit and its kind of annoying doing it one by one on the x then the y axis, when u can just slide it. i hope that helps explain what i mean. its like 3 am and its hard to think straight
mcheccyb
« Reply #3 on: January 31, 2009, 11:34:11 am »
yeah.
i agree, the slide tool is underused, and if it could be made to work a bit better or do something more it would be really cool.
polyGon_tError
« Reply #4 on: January 19, 2014, 02:55:28 am »
i added a Tool that can Slide Group of Point/Vertex, check here (it is Interactive):
 http://www.anim8or.com/smf/index.php/topic,4616.0.html
* you asked about (i think) Slide Along Edge Loop, it is possible but little tough. if it worth then reply and allow me so time!...
« Last Edit: January 19, 2014, 03:01:46 am by polyGon_tError »
lppena
  • Anim8or, does a body good.
« Reply #5 on: January 19, 2014, 04:42:30 am »
I envy you folks that understand how to compile these scripts you all are like the farmers of the computer world; without you we would all starve creatively. Kudos, to each and every one of you and thanks for making these scripts. Leroy.
