Author Topic: Shape help  (Read 7879 times)
djs162
Shape help
« on: January 24, 2009, 10:19:22 pm »
How would I make a shape like that that's kind of like a cylinder so its round but shaped like that?
benzjie
Re: Shape help
« Reply #1 on: January 25, 2009, 12:56:49 am »
i would just make a primitive N-gon, fil, select the outer edges, extrude them just a little and then delete the innerlines/points. Then convert to subdivided.
Re: Shape help
« Reply #2 on: January 25, 2009, 01:12:00 am »
Actually, all you need to do is create a Sphere, then use Non-Uniform scale.
Re: Shape help
« Reply #3 on: January 25, 2009, 03:45:45 am »
In Left view, make a cylinder that runs straight from left to right. Go to front view, select the cylinder and go to Build->Convert to mesh. Select the non-uniform scale button and then scale it whichever way you need to. That's it. If you're wanting an ellipsoid then do the same thing except with a sphere.
djs162
Re: Shape help
« Reply #4 on: January 25, 2009, 10:40:36 am »
il try that
