Author Topic: What is the bug & how can I fix it?  (Read 7209 times)
Lama
    • musiXtools stompboxes
« on: January 11, 2009, 12:45:32 pm »
Hi,
I need help once more.
I want to create a box and in one of the sides of the box it should be build a jack in  a hole.
Okay, the lines are a littel bit skew-whiff, but this is not the problem  ;)
The face around the hole is anyhow incorrect.
What is the best way to realize this objekt?
The first 2 fotos shows my trial object and I hope you can see what is wrong.
The third foto shows the real box - the example for my object.
Thank you for help,
Geli
Re: What is the bug & how can I fix it?
« Reply #1 on: January 11, 2009, 01:28:32 pm »
Your faces have to much sides. You should work with tri or quads.
Look at the image I attached. If you make the following cuts, your problem should be solved.
« Reply #2 on: January 11, 2009, 05:09:17 pm »
You will always get these errors with concave faces.  So try to steer clear of them.
