Author Topic: I need help!  (Read 8281 times)
small BUT POWERFUL
I need help!
« on: January 25, 2008, 01:40:07 am »
Hi, I've just started using anim8or recently..
And I need somebody to point me in the right direction. ???
The following link has a page with many anim8or files.
On the bottom file of this page there is a file called "Dino Scene"
http://www.geocities.com/anim8ortrade/downloads4.html#Model33
In this file there is a dinosaur figure made up of bones and a single object.
Every time you move a bone it moves the appropriate section of the object.
I am not sure how to do this- as every time I put bones through a single object
the only bone that has any effect on the object at all, is the bone that the object belongs to.
If you could help me, it would be very much appreciated
Re: I need help!
« Reply #1 on: January 25, 2008, 01:52:50 am »
You need to do what's called "skinning"  it's basically where you tell the bones what part of the object they will effect.
http://www.mp3d.info/Anim8ortutorials/index.html
Go to that website, and follow the 'beginners' tutorial on skinning (#6 called Painted Weights and how they work), then follow the 'intermediate' tutorial on skinning (the first tutorial in the intermediate section).  They should demonstrate how to do it.
« Last Edit: January 25, 2008, 02:01:18 am by hihosilver »
small BUT POWERFUL
Re: I need help!
« Reply #2 on: January 25, 2008, 01:57:07 am »
 ;D  Thanks, man!
I've heard of skinning before, but it just sounded gross.. :-\
Thanks anyway!
Re: I need help!
« Reply #3 on: January 25, 2008, 02:05:27 am »
Make sure you don't not do it just because it sounded gross.  It's really not that bad, especially using painted weights.  It's a part of the process though if you want to get a good skinned model ready for animation/posing.
Re: I need help!
« Reply #4 on: January 25, 2008, 11:13:31 am »
Heres`s our tutorial ( not in video format) , plus a load more ,
http://animanon.xtreemhost.com/index.php?board=32.0
 8)
