Author Topic: animating materials  (Read 10708 times)
Dragon Jedi0
animating materials
« on: December 18, 2008, 04:49:13 pm »
Lock if this question has been asked a billion times.
Is it possible to animate the material so you can switch from one material one frame and to another the next without having to do complex rendering and editing tricks?
For example:
youtube.com/watch?v=CjjhNyHewy0[/youtube]]http://uk.
Re: animating materials
« Reply #1 on: December 18, 2008, 09:54:02 pm »
Unfortunately Anim8or cannot do this (yet).  There are, however, a couple of possible workarounds.  For example, to replicate the attached video, you could render the entire scene twice, once with a red ball, and again with the material changed to blue, then use video editing software to fade from one video to the other.  Alternatively, you might be able to achieve a similar effect using a white ball, being illuminated by a light (or set of lights) that changes colour (which can be animated).  You cannot define which objects are affected by which lights in Anim8or like you can in some other packages, so the lights will affect all the elements in the scene, but perhaps with careful placement, aiming and light range settings you might have some luck.  I am sure there other workarounds as well, but direct animated transition of material elements cannot be done with Anim8or at the moment, unfortunately.
NOTE:  I think Terranim8or has some functionality in this area, it might be worth investigating.
xalener
« Reply #2 on: December 19, 2008, 12:31:39 am »
It might kill your computer, though...
« Reply #3 on: December 19, 2008, 06:12:16 am »
Terranim8or has indeed has a this function. Read more about it here: http://www.biederman.net/leslie/terranim8or/terranim8or.htm
and here: http://www.biederman.net/leslie/terranim8or/settings.htm#animated material
I never really used it so i don't really how it works, but you can find out.
Dragon Jedi0
« Reply #4 on: December 20, 2008, 03:32:13 pm »
Grr.  That's how I made the example video.  A little inconvienient at the moment, but I guess if and when Anim8tor gets this ability, I'll continue to duplicate and fade edit.
