Author Topic: V97d bug  (Read 15506 times)
Pincho
V97d bug
« on: December 18, 2008, 12:08:25 pm »
Rendering never ends. Using ART, waited several hours, picture reached the top of the screen, but black bar just stopped in the same place. Did this twice. I pressed PrtScn to show you..
Re: V97d bug
« Reply #1 on: December 18, 2008, 03:10:10 pm »
Just giving a screenshot isn't enough to help us. At least email Steve the .an8 file along with all the textures used in a .zip file and let him know what AA settings (Samples per pixel and sampling method) and the image resolution you rendered it at.
Re: V97d bug
« Reply #2 on: December 18, 2008, 03:20:06 pm »
It looks like you have set a bigger height for you render then your screenresolution. If you set the height of your render on a larger number then the height of your screen resolution, the render will go on outside your screen. This way the render looks finished, since it reached the top of your screen, but it still needs some pixels to render. Click and drag on the image to see the top of your render.
Pincho
Re: V97d bug
« Reply #3 on: December 18, 2008, 04:18:22 pm »
It was running all night, should have finished in about 3 hours, but had 8 hours. Res = 1024 * 768. My own screen is 1152*864.
« Last Edit: December 18, 2008, 04:20:05 pm by Pincho »
Re: V97d bug
« Reply #4 on: December 18, 2008, 05:58:54 pm »
That is strange then. I don't know if this is a bug, your computer just freezed or it's about your settings. Maybe you could post what kind of setting you used: Resolution, AA, AO on or off, what kind of materials (dielectrics/glossy/reflections) or maybe even better: the .an8 file.
odp04y
Re: V97d bug
« Reply #5 on: December 18, 2008, 06:15:19 pm »
This happens to me occasionally after a long render, but not for more than 2 minutes. Not 5 hours :o
computeruser28
Re: V97d bug
« Reply #6 on: December 23, 2008, 02:15:51 am »
you should be able to drag the render around to see the part you don't see. have you tried that? or go prtsc all the parts of the picture and get them all in mspaint and make your picture there if the rendering is already done.
rctmonger1108
Re: V97d bug
« Reply #7 on: February 01, 2009, 01:38:01 pm »
just a random question...is that supposed to be a dalek?
Trying to do too many things at once: game design, programming, 3D modelling & animation, and graphic design.
http://johnsongames.110mb.com
http:///johnsongames.lefora.com
xalener
Re: V97d bug
« Reply #8 on: February 01, 2009, 08:08:43 pm »
Well, of course!
jdonzae
Re: V97d bug
« Reply #9 on: February 04, 2009, 02:59:38 pm »
I have to giv you your props. That model looks pretty darn good
onespirit5777
Re: V97d bug
« Reply #10 on: March 08, 2009, 10:53:10 am »
For what ever reason mine is doing the same thing. Never had this problem untill this week. Don't know what has changed. I went into regedit and removed silcon valley and deleted the program and unzipped the program again. Haven't tried a long render to see if this solved the problem. And it will no longer go into screen protection mode while rendering.
« Last Edit: March 08, 2009, 04:34:33 pm by onespirit5777 »
