Author Topic: making 15agon  (Read 19764 times)
aGMuser
making 15agon
« on: December 05, 2008, 03:43:16 pm »
I click n-gon and created on sixagon, but when I clicked it, there was no option to change it to 25 agon.I clicked the icon and search the manu without result.How to do it?
odp04y
Re: making 15agon
« Reply #1 on: December 05, 2008, 06:13:47 pm »
Go to Build>Primitives>Ngon and type 25 in dialog box, build new ngon with ngon tool and you'll have a 25agon
aGMuser
Re: making 15agon
« Reply #2 on: December 06, 2008, 06:34:32 am »
Ok, thanks!
aGMuser
Re: making 15agon
« Reply #3 on: December 06, 2008, 07:05:07 am »
It looks like the 15agon has been created without face.How I can add face to my 15agon?
Re: making 15agon
« Reply #4 on: December 06, 2008, 07:32:53 am »
Select it build>fill. Now the n-gon fill with faces. If you want just one face: select all the faces in point edit mode and hit shift+m.
aGMuser
Re: making 15agon
« Reply #5 on: December 06, 2008, 03:33:41 pm »
Thaks, Floyd!But there is still something which I can not do myself --->
mcheccyb
Re: making 15agon
« Reply #6 on: December 06, 2008, 04:51:46 pm »
you can't have a shape with acute angles with only 1 face behave how you want to, you shall have to split it up into multiple faces i'm afraid.
Re: making 15agon
« Reply #7 on: December 06, 2008, 05:13:32 pm »
Basically if you have a single face, it cannot be concave or you'll get something like this.  Therefore, you need to split the single face into multiple faces that are not concave (you can do this with the cut tool).
aGMuser
Re: making 15agon
« Reply #8 on: December 08, 2008, 05:26:29 am »
But the upper part is concave with one face, right?
Francesco
Re: making 15agon
« Reply #9 on: December 08, 2008, 06:21:13 am »
Yes you're right aGMuser, the upper part is concave too but it doesn't show the same problem of the lower part. This is quite strange. Could you post your project or maybe just the exported object that shows that behaviour?
Claude
Re: making 15agon
« Reply #10 on: December 08, 2008, 11:34:09 am »
The videocard driver tesselate your polygone into triangles
and your videocard renders it as a convex polygone
resulting in a folded polygone.The bottom part is doubled.
aGMuser
Re: making 15agon
« Reply #11 on: December 08, 2008, 01:17:37 pm »
There is nothing complex.I just made 15agon, convert it to mesh and reshape it, pressed built>fill, convert all faces into one.This is it.
I can't understand you.Will you explain me more detailed?
Claude
Re: making 15agon
« Reply #12 on: December 08, 2008, 03:14:07 pm »
The bottom part is made of 2 layers.
A good way to see it would be to select the
4 points inside the polygone(fig 2) and move them
into the screen.Then rotate the mesh to see how it's rendered.
aGMuser
Re: making 15agon
« Reply #13 on: December 08, 2008, 03:45:31 pm »
Never mind, it turned out it isn't a problem. :)
Francesco
Re: making 15agon
« Reply #14 on: December 08, 2008, 06:35:08 pm »
Good that you got rid of the problem aGMuser.
Claude, thank you for the details, I didn't know those particulars but after reading your posts and playing around within Anim8or I undestood the mechanism.
