Author Topic: can't merge points  (Read 18090 times)
stipend
can't merge points
« on: November 26, 2008, 09:07:44 pm »
every time i attempt to merge points i get a dialogue that says "no points selected" i select 2 points! help
Re: can't merge points
« Reply #1 on: November 26, 2008, 09:23:50 pm »
Hi, just so we are on the same wavelength, do the points that you select show in white on the screen ?
stipend
« Reply #2 on: November 26, 2008, 09:31:12 pm »
« Reply #3 on: November 26, 2008, 09:41:10 pm »
Now I see the problem. Your points are waaaaaaay too far from each other.
Move one point really close to the other even on top of each other then select Merge Points and if 0.500 doesn't work change it to 1 or 2 or even more.
When using high numbers make sure there are no other points within distance that you don't want to merge with the first two. ;)
stipend
« Reply #4 on: November 26, 2008, 09:43:12 pm »
even when they're really close they don't merge, i still get "no points selected" there isn't even a dialog to enter #s
Francesco
« Reply #5 on: November 26, 2008, 09:46:55 pm »
Maybe they belong to two different meshes? You can only merge points belonging to the same mesh.
Francesco
« Reply #6 on: November 26, 2008, 09:48:29 pm »
No, I got it now. You're trying to merge points of two paths. You cannot, sorry, but you can join the paths together, if that helps.
stipend
« Reply #7 on: November 26, 2008, 09:50:55 pm »
how do you join paths together?
Francesco
« Reply #8 on: November 26, 2008, 09:52:44 pm »
Select them both, then build > join splines. Even then, you have to build a real mesh out of it before you can merge points. To convert a spline/path to a mesh. extrude or lathe it, again from the build menu.
stipend
« Reply #9 on: November 26, 2008, 10:00:05 pm »
ah, i think i've got it, that makes it incredibly tricky to model tho XD
Francesco
« Reply #10 on: November 26, 2008, 10:06:23 pm »
Oh, it all depends on the way you want to model... some ways can be easier than others, and some can be quicker than others again - but maybe not that easy at the same time. It all depends on what you want to do and how much time you're ready to invest in studying new stuff. I'm getting a grip on the overall techniques, and this forum is fulfilled of skilled people. You just have to ask and you'll get some good pointers and advices. Have fun with Anim8or!
stipend
« Reply #11 on: November 26, 2008, 10:11:08 pm »
thank you kindly for your help!  ;D
if any other questions come up i'm glad to have you around!
(do you has an msn or a deviantart?)
Francesco
« Reply #12 on: November 26, 2008, 10:17:32 pm »
You're welcome stipend.
Unfortunately I'me quite new to 3D art (to graphic arts in general) hence no deviantart. About MSN and alike, I'm a bit allergic to messengers and chats, the forum is my ideal habitat: every issue that we could point out would be useful for all the future readers (just like me and you).
stipend
« Reply #13 on: November 26, 2008, 10:21:26 pm »
ooh, i'm good /w photoshop http://nategrafix.com lemme know if i can help you!
benzjie
« Reply #14 on: November 27, 2008, 03:26:58 am »
you can model the "spline"way. Draw a cube, convert to mesh, delete all but 2 points so you're left with one edge. Select the "add edge "  button and do whatever you want to do.  Repeat this process for other "splines".
