Author Topic: Animation problems  (Read 7299 times)
onespirit5777
Animation problems
« on: November 26, 2008, 06:34:34 pm »
I'm still new to this. When I animate something it will move backwards a little and then in the direction I wanted it to go. I look at the key frame and it will show it in the opposite direction and I didn't do it.
Re: Animation problems
« Reply #1 on: November 26, 2008, 07:00:13 pm »
If you check the graph you will see the parameter path.
You can fix it from there by adjusting the points.
onespirit5777
« Reply #2 on: November 26, 2008, 09:13:10 pm »
thank you
