Author Topic: Help!  (Read 6874 times)
Inxth
Help!
« on: November 26, 2008, 03:07:07 am »
Can someone pls help? I need someone ter help me....
How do you change the ground??
Re: Help!
« Reply #1 on: November 26, 2008, 11:31:21 am »
Inxth ---
In order for others to help you, it's always helpful if you provide more detail about WHAT you want to change, or HOW you want it to appear.  I assume that you're referring to the default checkerboard pattern, correct?  If so, you can remove it from your render by clicking Settings > Environment... in the Scene Mode, and un-checking Ground Grid.
You can always create and add your own flat plane, desk, building, or ground on which your other objects can "sit," too.
« Last Edit: November 26, 2008, 11:35:32 am by RudySchneider »
Inxth
Re: Help!
« Reply #2 on: November 26, 2008, 05:05:25 pm »
Thanks! I'll keep that in mind.
______________________________________________________________
Click here to feed me a Star Fruit!
Get your own at Flyffables!
