Author Topic: How good are the anim8or tutorials?  (Read 9075 times)
animation-nation
« on: November 24, 2008, 10:18:50 am »
Once again, I'm new to anim8or and I want to learn how to use it. So how good are the tutorials at this website? Will I learn a lot from all the tutorials?
Re: How good are the anim8or tutorials?
« Reply #1 on: November 24, 2008, 10:24:12 am »
Doing the tutorials on this site will give you the basic understanding on how the model, rigg and animate using anim8or. There pretty helpfull when you just get started. I suggest to go through the eggplant and simple walk tutorial. Because these give an easy explanation on the basics. After that try to model something easy yourself.
O, I almost forgot: read the manual!!! Most of the answers on your questions about using anim8or can be found here. This is a recommendation for every starter.
« Last Edit: November 24, 2008, 10:27:50 am by floyd86 »
falloffalot
« Reply #2 on: November 25, 2008, 01:58:36 pm »
Google is great, search for tutorials cause there are loads out there, also check out animanon.com for extra help and basic tuts if needed. Link in bottom left corner <-------- over there.
A good way is to play with Anim8or and try everything and see what happens, you can always undo (Ctrl + Z)
