Author Topic: Convert from .an8 to .nif  (Read 6670 times)
nextmastermind
  • The Virdeus
« on: November 22, 2008, 10:39:23 pm »
Is there any way to convert it from a .an8 file to a .nif file?
Re: Convert from .an8 to .nif
« Reply #1 on: November 23, 2008, 03:32:47 pm »
I've done a little research and it seems that the file structure and syntax of the .nif format is kinda secret, it's not possible to export models to this format unless you have purchased some software that can do that.
So it's (obviously) impossible to write an export plugin for Anim8or... You will have to export your .an8 models as .obj and find an external converter  :-\
