Author Topic: Fire in Anim8or  (Read 13408 times)
Fire in Anim8or
« on: November 03, 2008, 05:14:40 am »
http://au.
it2
Hello,
Falloffalot asked a question on animanon re this. I can't get onto the site but thought it would be helpful here anyways, for those who haven't heard of terranim8or.
Best thing to use is terranim8or with an animated material placed on a background.
http://www.biederman.net/leslie/terranim8or/terranim8or.htm
use version 6.6.1
The source for the anim8ted background needs to be a series of jpegs.
You can also use terranim8or's built in fire plug in, but the animated material works better.
The youtube link is is just a quick render to give you the idea. Of course if you fiddle you'll get a much better result.
cheerios
below is one of the jpeg's making up the animated texture
« Last Edit: November 03, 2008, 05:16:23 am by headwax »
falloffalot
Re: Fire in Anim8or
« Reply #1 on: November 03, 2008, 10:58:56 am »
Thanks Headwax just what I was looking for.
I will have a look and see what I can do.
Re: Fire in Anim8or
« Reply #2 on: November 05, 2008, 05:39:53 am »
no problemo
will stick a mix avi of effects later, dont forget 661
meanwhile
« Last Edit: November 05, 2008, 05:46:31 am by headwax »
Re: Fire in Anim8or
« Reply #3 on: November 05, 2008, 05:54:26 am »
http://au.
first scenes ( pre ballerina)   are eg of  terranim8or fire, first part    plugin, second part is  animated texture, 3rd part with 'ballerinas'   is my other program fun with some old anim8or figures I made for some comps.
hope  you enjoy
cheers
« Last Edit: November 05, 2008, 06:01:33 am by headwax »
Indian8or
Re: Fire in Anim8or
« Reply #4 on: November 05, 2008, 11:14:36 am »
I like the particle effects more than the textured one.  Particle effects with sufficient number of particles and smoke really look cool.
falloffalot
Re: Fire in Anim8or
« Reply #5 on: November 05, 2008, 03:04:43 pm »
Thanks Headwax thats great, which version of Terranim8or are you using as mine is different to yours.
odp04y
Re: Fire in Anim8or
« Reply #6 on: November 05, 2008, 03:26:47 pm »
Version 6 of Terranim8or uses rotating cubes for the fire version 7 uses textures planes.
It's useful to have both. (Also as V6 has rain and snow)
