Author Topic: Transparency not working  (Read 10673 times)
Sinani201
  • PI=3.1415926535...
« on: January 21, 2008, 01:37:01 pm »
I was using Anim8or and when I applied transparency to my material, there was no transparency, just solid.
I have Vista using DirectX 10 as my graphics card.
The most exiting signature you've never seen...
 _____   _   __   _       ___   __   _   _   _____   _____   ___
/  ___/ | | |  \ | |     /   | |  \ | | | | /___  \ /  _  \ |_  |
| |___  | | |   \| |    / /| | |   \| | | |  ___| | | | | |   | |
\___  \ | | | |\   |   / / | | | |\   | | | /
Re: Transparency not working
« Reply #1 on: January 21, 2008, 01:49:38 pm »
Transparency is generally only apparent in an actual render; you can't normally "see" the effects of a transparent texture in the edit or scene window.
« Reply #2 on: January 21, 2008, 05:20:28 pm »
Go "view>preferences" and check the "transparency" box and any others you want.
Sinani201
« Reply #3 on: January 21, 2008, 08:12:41 pm »
Thank you hihosilver!
