Author Topic: Extrude no Work for me, help  (Read 16593 times)
jmunoz
« on: January 20, 2008, 09:06:23 pm »
 I try to do the tutorial  "How to Make An Eggplant" . but extrude no work, and use TOP views, but seem flat pentagon.
help me please ???
thx
Re: Extrude no Work for me, help
« Reply #1 on: January 20, 2008, 09:34:18 pm »
Unfortunately, jmunoz, that's not quite enough information.  You need to explain a bit more about what you tried, and what happened.  It also helps if you can post a screen shot of the problem you're having, so we can actually SEE what you're talking about.
When you try to extrude something, using Build > Extrude..., you can specify along which axis you want to extrude (X, Y, or Z).  Make certain you choose the correct axis, or you may end up with something very strange.
« Last Edit: January 20, 2008, 09:35:58 pm by RudySchneider »
jmunoz
« Reply #2 on: January 21, 2008, 04:05:51 pm »
sorry ,  I try to do the tutorial  "How to Make An Eggplant" . but extrude no work, and use TOP views, but seem flat pentagon.
Start in the Object Editor.  Use the View->Top command to switch to the top view so that it fills the screen.  Select Build->Primitives->N-Gon from the menu and set the value to 5.  Select Add Polygon  from the toolbar, click in the center of the screen and drag about 2 squares to add a pentagon.  Now select Build->Extrude from the menu.  In the dialog, select the Y-axis, 20 units, 1 segment, cap both ends, and don't tessellate caps.
I Will try to do that, but no work
in this link I have Print Screen.
jmunoz
« Reply #3 on: January 21, 2008, 04:07:35 pm »
« Reply #4 on: January 21, 2008, 04:23:00 pm »
Hmmm...
Works for me.  However, since you're extruding it down the Y-Axis, you won't actually SEE the results until you change your view!  Try looking at perspective or front view.  Or, better yet, View > All.
jmunoz
« Reply #5 on: January 21, 2008, 08:24:27 pm »
no Works for me.  I 've  changed the  view! . but no work  and seen  ok only in View ORTHO
version 0.95c
thx
« Reply #7 on: January 22, 2008, 12:18:32 am »
Ok,now I'm confused.  Your second image looks exactly right to me!  You've now got a pentagon that's extruded down the Y-axis, just like you set up.
What makes you say it doesn't work?
« Reply #8 on: January 22, 2008, 12:29:47 am »
Make sure you followed these steps:
-after you've made the pentagon, go into point edit mode and select the faces around the edges of the pentagon.  Use the extrude tool to extrude the legs of the eggplant (the extrude tool in point edit mode, not "build>extrude")  That should give you the right result.
« Reply #9 on: January 22, 2008, 11:23:04 am »
Aha!  So, correct me if I'm wrong, but it's the NEXT step with which you were having problems!  In other words, once you have the basic pentagon extruded, you want to extrude the "roots" of the eggplant out.  If that's the case, hihosilver's explanation should help you with that.
jmunoz
« Reply #10 on: January 23, 2008, 03:47:05 pm »
the the eggplant out
jmunoz
« Reply #11 on: January 24, 2008, 02:13:33 pm »
no is working thx very much
« Reply #12 on: January 24, 2008, 03:02:35 pm »
Hopefully, these screen shots will help...
« Reply #13 on: January 24, 2008, 03:03:05 pm »
And one more...
