Author Topic: Transparent Renders...  (Read 11112 times)
Sluggs
  • Anim8or user since May 2004
    • Satans-Comrade
« on: October 23, 2008, 05:59:09 am »
Is there any way to render a model on a transparent background?
I use anim8or to make 3D images too, (as well as models for my game levels), for use on websites, etc, and I would like to be able to render my models with a transparent background.
I'm a bit of a noob when it comes to making transparent images, so any help is greatly appreciated!  :D
KiwiNM8OR
Re: Transparent Renders...
« Reply #1 on: October 23, 2008, 07:08:48 am »
The only recommendation I can make is to use a transparent plane behind your model perhaps with some kind of texture as in a combination of diffuse and 100% bumpmap (same texture as diffuse). By default Anim8or background, panorama and cubemap can only be textured as they do not support ART Attributes (transparent, glossyreflector and dielectric). Use a plain coloured background, say black (but do experiment with different colours) and use a textured transparent plane behind your model and make it big enough to exceed the Field Of View (FOV) of the camera in Scene Mode.
I hope this is what ya need to know, however in Scene mode be careful how you use lighting as anything transparent can be lit up too, but there is a way to alter the material so it's not so reflective but still noticable.
I'm not too sure if this is what you mean but IF it is then make the transparent plane somewhat(but do experiment) like thus:
Create a plane and rotate it so it is face on. Experiment with colours first as you may not want to texture it. In materials editor set transparency in the range of 0.1 to 0.5. There are other ways to create transparency nut I recommend this following link: http://www.anim8or.com/download/preview/art_raytracer.html
As for the render you can also render the alpha channel for .gif transparency.
Meanwhile...
Happy Anim8ing
« Reply #2 on: October 23, 2008, 01:42:49 pm »
Another way to do this is render the "Alpha channel" as well.  You then use a program such as photoshop or something to use this as a mask and to remove the pixels that don't matter.  Use a background color that will mix in well with the model.
almost cool
  • The Truffle Shuffle
    • www.deadboltdevelopment.com
« Reply #3 on: October 24, 2008, 10:49:06 pm »
gifworks can 2 if u dont have pshop, look it up
Sluggs
    • Satans-Comrade
« Reply #4 on: October 28, 2008, 11:34:17 pm »
Thanks guys! I will try hihosilver's suggestion first, see how I go!  ;)
