Author Topic: .Obj export crash (broken material used)  (Read 9463 times)
CowTail
« on: October 21, 2008, 07:33:34 pm »
Attached is the file as the example. I'm using Windows Vista Ultimate but anyone should be able to reproduce it...
Just open the file and you should see a sphere with a material with bad references to a texture file. Go to Object->Export, export the file and it'll crash and produce an invalid .obj/.mtl file.
Re: .Obj export crash (broken material used)
« Reply #1 on: October 22, 2008, 12:11:18 am »
Good find there CowTail.  I did what you said and was able to reproduce the crash.
« Reply #2 on: October 24, 2008, 02:33:42 am »
#097-025 - Export file with missing texture to Obj format crashes.
Thanks for the bug report.  It was easy to fix.
