Author Topic: How the set camera's position  (Read 19430 times)
Laryllan
« on: January 17, 2008, 01:55:40 am »
Hi there.
I'm new to ASL and I think it sounds quite cool. But there is one point I didn't find an answer to...
Is there a possibility to set the position of the camera in a scene?
Thank you guys very much,
Laryllan
Claude
Re: How the set camera's position
« Reply #1 on: January 17, 2008, 09:29:44 am »
The only way to set the camera position is through a controller script.
Leslie's tutorials should get you started:
http://biederman.net/leslie/tutorials/ASL%20Scripting/ASL_scripting.htm
Laryllan
« Reply #2 on: January 17, 2008, 12:59:46 pm »
Thank you very much.
This is a beginning... But not exactly what I wanted. Maybe there even is no possbility at all to do all the stuff I 've wanted to be done automatically.
I have some animations that need to be rendered from the same point of view. And I don't need every frame just about every 5th or so (for creating an animated GIF).
So the perfect solution would be: I press an "button" in Anim8or. The camera is set at the correct position. The background would be colored like I wish. The scene would be rendered (and saved). The animation would go 5 frames further -> next rendering. Ans so on...
I could write an external program to simulate mouse and keyboard events. But I think it would be quite more elegant to write an ASL script with this abilities.
Best regards,
Laryllan
« Reply #3 on: January 18, 2008, 12:44:35 am »
The only scripts presently supported in the Scene editor are controller scripts.  Perhaps I'll have time to add more someday.
karate5662
    • my mini city
« Reply #4 on: January 18, 2008, 08:36:27 pm »
maybe you could delete the frames in between what you want rendered and render a movie in .bmp format.
