Author Topic: Detach Face bug  (Read 10139 times)
5L1D3R
Detach Face bug
« on: September 24, 2008, 06:34:27 pm »
Had this issue pop up while working with a high-res model...
When trying to detach faces, Anim8or just closes.   ...no errors or messages of any kind, no lockup, it just closes. I tried with different models, and it appears to only happen when trying to detach a large number of faces.  Not sure how many faces - first noticed it when working on a 50,000+ face object.  ...had at least 10,000 faces selected...
Took a low-res model and subdivided the faces a couple times to make it high res, detached half the faces, and  ->POOF<-  Anim8or closes.
Re: Detach Face bug
« Reply #1 on: September 25, 2008, 02:15:42 am »
How much RAM do you have? Can you send me an example?  I tries detatching half of several large meshes and it worked.
