Author Topic: Chess: King Piece  (Read 34805 times)
Guilherme Amorim
  • Jr. Member \o/
Chess: King Piece
« on: September 24, 2008, 01:11:03 pm »
Hi!
 ;D I really love reproduce real things in 3D...
But I'm not the kind of guy that is good on it x)
And a lot of times i just put my works to side and forget it
BUT now I'll try to no to that x)
lol
Here is a piece :)
What do you think?
Made in Brazil
Re: Chess: King Piece
« Reply #1 on: September 24, 2008, 01:14:49 pm »
Very nice, looks very regal.
« Reply #2 on: September 24, 2008, 01:58:47 pm »
Beautiful !
It looks almost like the piece I play with :)
« Reply #3 on: September 24, 2008, 02:58:57 pm »
very good - are you planning to make the rest of the set too?
and could i ask what material and render settings you used?  it has a really nice glowy feel which i've never been able to achieve.
« Reply #4 on: September 24, 2008, 06:45:14 pm »
The shadows look excellent!  I take it that you're using a lower value for the main section of the shadow, but you also used some lights with much higher values.  It gives you a very nice realistic effect.  I may have to try it for myself sometime!
« Reply #5 on: September 24, 2008, 07:17:32 pm »
I also like the basic, yet distinct horizon, it definitely adds depth.
Guilherme Amorim
  • Jr. Member \o/
« Reply #6 on: September 24, 2008, 07:43:09 pm »
Thanks, I thought It was too simple :D
I did this piece some months (one or two) ago so I can't say if I used the glow effect of Paint.net =\
but I'm a bit sure that I did
And yes, I'll try to do whole set :)
Here's one direct from ani8or:
if someone get a little hint to the material to the black pieces, I would be grateful, the one I made is too dark
I'm putting the .an8 file here if you want to see the settings ;)
Aw, actualy, there are four lights, infinite, one coming from bottom(to represent the reflect of the ground, making shadow), another from up, the shadow is soft 100, and two in diagonal, in in the same position, one creating a shadow soft 20, and a normal volume shadow(I think it needs to be changed to raytrace to appear now)
« Last Edit: September 24, 2008, 08:40:10 pm by Guilherme Amorim »
Made in Brazil
« Reply #7 on: September 25, 2008, 09:29:41 am »
For your black piece you might try
amb 2
diffuse 1
spec 0.5
em 0
rough 30
brilliance 1
R 17 G 17 B 17 or a bit less but more than 0
Guilherme Amorim
  • Jr. Member \o/
« Reply #8 on: September 25, 2008, 10:58:53 pm »
amb 2
diffuse 1
spec 0.5
em 0
rough 30
brilliance 1
Perfect! Thank you!
Made in Brazil
KiwiNM8OR
« Reply #9 on: September 26, 2008, 03:33:43 am »
Well made but I don't think ART supports fog yet though scanline still does
Meanwhile...
Happy Anim8ing
« Reply #10 on: September 26, 2008, 01:51:58 pm »
almost cool
  • The Truffle Shuffle
    • www.deadboltdevelopment.com
« Reply #11 on: September 26, 2008, 11:24:45 pm »
WOW, that's wicked sick! :o (excuse my skate talk)
it looks pretty high poly.(im nudging towards 'Wire frame?')
Were the ridges actually extruded, modeled (i mean vertex by vertex), or a texture?
and lastly, how long have you been using anim8or?
Three parentheses,a new record.
Guilherme Amorim
  • Jr. Member \o/
« Reply #12 on: October 02, 2008, 11:07:32 am »
No, but I'll use ART without showing the background xD
Perfect! Thank you!
You're most welcome :)
=D
I'm not sure I understood you:
"(im nudging towards 'Wire frame?')"
Actually they are extruded, and the I converted it to subdivided to make it smoth
Almost a year :P
Anim8or is the first 3D modeller I have ever used.
I learning yet, this is the best model I did, coz before I used to worry just with lights and shadows (using downloaded models ).
« Last Edit: October 02, 2008, 11:14:57 am by Guilherme Amorim »
Made in Brazil
falloffalot
« Reply #13 on: October 02, 2008, 05:31:51 pm »
Great camera angle and and I'm with hiho the shadows look the biz.
Very nice
Guilherme Amorim
  • Jr. Member \o/
« Reply #14 on: October 02, 2008, 09:39:13 pm »
I did the last piece today, the horse, it's horrible xD
and Rook (or Hook),aw... the "tower"!  is horrible too
The "tower" I can fix, but the horse is a problem, I'm a very bad modeller xDD
Made in Brazil
