Author Topic: Max reflections  (Read 30616 times)
KiwiNM8OR
Max reflections
« on: September 16, 2008, 03:43:39 am »
I've been experimenting with the number of reflections glossy reflector can do and I think I've hit the limit but ya never know - somewhere out there in Anim8or Land someone can probably do better...
Meanwhile...
Happy Anim8ing
Re: Max reflections
« Reply #1 on: September 16, 2008, 06:52:14 am »
i also noticed the ceiling reflections look a bit broken in places, ie. the hemispheres aren't fully shown in some cases.  is that a deliberately designed feature of the scene, a design flaw, or a program bug?
KiwiNM8OR
Re: Max reflections
« Reply #2 on: September 17, 2008, 03:37:44 am »
I'm not too sure myself. I suspect a design flaw because I accept that at a programming level I don't understand exactly how the reflection process works. But I have had that flaw in other experiments. It could be an alignment of the mirrors too. I started off with a sphereinder with a flat top and base and experimented with different numbers of sides to see what offered the best reflections. Therefore the top and base are not "flat" but divided (like a pie chart) according to the number of sides. I'm not sure if that makes a difference but that was how it was made. In this example I just used 4 (flat, not divided) sides. Then I used Edit=>Subdivide faces a few times so that I could then use the taper modifier to "lift" the view of the ground grid in the distance. In Scene mode it is rendered with a FOV of 90 degrees. The file is there for interest and inspection. Cheers for the view.
Meanwhile...
Happy Anim8ing
Re: Max reflections
« Reply #3 on: September 19, 2008, 02:17:57 am »
The max level of reflections (and all other things like refraction, etc.) is set to 12.  But I'll add an attribute "RayDepth" that you can set to change the level.  Here's your image with the value set to 64 (but I think a value of 30 or so would give the same result).
Note: dielectric materials become horribly slower as the max depth increases, up to a factor of two for each increase of RaDepth by 1.  Be careful how you use this new setting when it's available.
« Last Edit: September 19, 2008, 02:23:15 am by Steve »
KiwiNM8OR
Re: Max reflections
« Reply #4 on: September 19, 2008, 05:44:47 am »
Awesome Steve. Cheers very much. I like the improvement. Looking forward to the update.
Meanwhile...
Happy Anim8ing
Re: Max reflections
« Reply #5 on: September 19, 2008, 06:38:14 pm »
...and so we finally see kiwiNM8or's original vision, in all its glory.  looks great.  roll on 0.97d, steve!
KiwiNM8OR
Re: Max reflections
« Reply #6 on: September 20, 2008, 04:50:45 am »
Now that I know that currently the RayDepth is set to the default of 12 I can shape my current experiments more effectively knowing the actual setting. Cheers.
Meanwhile...
Happy Anim8ing
Re: Max reflections
« Reply #7 on: September 20, 2008, 08:44:26 pm »
I almost have the v0.97d update ready to post.  It will support user settable max ray depth plus ambient occluders.  For an example of what they can do, I am posting an image that has no lights, but uses ambient occlusion an ambient intensity of 3.14 to treat the whole sky as a light.  It takes a lot of samples to get rid of the noise for this.  One image uses 64x AA and the other uses 256x.
karate5662
    • my mini city
Re: Max reflections
« Reply #8 on: September 21, 2008, 07:58:59 pm »
maybe steve should have a thread for all the test renders with the next version.
Darkjesture
Re: Max reflections
« Reply #9 on: September 21, 2008, 08:12:02 pm »
How are you guys making these reflections?
KiwiNM8OR
Re: Max reflections
« Reply #10 on: September 21, 2008, 11:35:02 pm »
Darkjesture : rather than explaining here please follow this link where I have provided an explanation there. Cheers for your interest. http://www.anim8or.com/smf/index.php?topic=1064.0
Thanks again to Steve for your attention in this area
Also some examples by thecolclough can be found at : http://www.anim8or.com/smf/index.php?topic=1288.msg9394#msg9394
« Last Edit: September 22, 2008, 01:02:57 am by KiwiNM8OR »
Meanwhile...
Happy Anim8ing
Darkjesture
Re: Max reflections
« Reply #11 on: September 22, 2008, 12:14:21 am »
Wow thats insightful i didnt know you could do that ;)
VBSmiles
Re: Max reflections
« Reply #12 on: September 22, 2008, 02:14:24 am »
Cartoon madness :)
onespirit5777
Re: Max reflections
« Reply #13 on: September 22, 2008, 10:28:04 pm »
just having some fun
onespirit5777
Re: Max reflections
« Reply #14 on: September 23, 2008, 11:38:54 pm »
I've tried playing with RayDepth but not doing something right.
do the settings go under
float, int, ?
