Author Topic: Key Framing Modifiers  (Read 11152 times)
Bmer
« on: September 02, 2008, 09:36:03 am »
Is it possible to key frame modifiers?
Re: Key Framing Modifiers
« Reply #1 on: September 02, 2008, 09:57:11 am »
No... You have to use bones or Morph targets, it depends on the kind of animation you want to do.
I would use bones to simulate "bend" and "twister" modifiers and morph targets for "curvature", "skew" and "taper".
« Reply #2 on: September 02, 2008, 10:00:12 am »
A modifier is applied to a wireframe, and once applied the modifier itself is gone, leaving the modified wireframe.  I assume a modifier can be used to create a morph object, which can be key framed, but I have not actually tried this so I would suggest a bit of experimentation.
« Reply #3 on: September 02, 2008, 10:05:06 am »
Quote from: ENSONIQ5
... I assume a modifier can be used to create a morph object, which can be key framed, but I have not actually tried this so I would suggest a bit of experimentation.
Yes, you can use a modifier to create a morph target (I've just tried it :))
« Reply #4 on: September 02, 2008, 10:12:23 am »
Cool.  Something worth remembering, no doubt!
« Reply #5 on: September 03, 2008, 04:37:29 am »
yep, and you can scale and rotate the points as well as just moving them up and down.
« Reply #6 on: September 03, 2008, 06:14:11 am »
and you can morph from one extruded spline to another with morph envy
