Author Topic: EggPlant tutorial to be revised  (Read 5703 times)
feejo
« on: August 26, 2008, 12:11:58 pm »
I just start the eggplant tutorial on that site. It miss a command
" Switch to view ortho" after doing the Extractude. I hope it will be fixed for future generations. Thanks
Also where it say
" If you switch to wire frame mode, you will notice that the top and bottom faces are not divided into triangles, but are left as single, 5-sided polygons.  This allows the extrusion of the base into the stem to work. "
We don't even know what is a wire frame mode, maybe to place it a little below.
Also I am stuck at
Switch to face mode
I don't see any yellow or blue. ???
I am trying th hand tutorial. No luck eather.
Now you switch to point-edit mode  where most of the work will be done.  This also switches the screen into wireframe and shows individual points as well for easier editing.
Those individual points dose not appear, what have I done?
« Last Edit: August 26, 2008, 12:29:13 pm by feejo »
Re: EggPlant tutorial to be revised
« Reply #1 on: August 26, 2008, 12:54:50 pm »
You should first read the manual and learn the basics of anim8or and what the tools are. After that do some tutorials to work with the tools.
