Author Topic: vetex reducing script  (Read 15083 times)
neo
  • "I can see you."
« on: August 20, 2008, 11:38:12 pm »
i need a scipt that will reduce the number of vertexs in a complicated model so it takes up less graphics memory
This is not real.
Re: vetex reducing script
« Reply #1 on: August 21, 2008, 01:52:44 am »
The newest version of Terranim8or has a polygon reducer.  I believe it does triangulate the model, but with a vertex reducer that's what you'll ordinarily get unless you do it manually.
Kubajzz also has some great mesh cleanup scripts in his blog at CG-nation that would definitely be useful for manual cleanup of your mesh.
neo
  • "I can see you."
« Reply #2 on: September 01, 2008, 02:53:16 am »
thanks for that mate its a real help.
still if any one has any other ideas please tell me
This is not real.
« Reply #3 on: September 23, 2008, 11:11:08 pm »
Neo this is true...be good if anim8or has this plugin... ;)
in Terranim8or..dont work..right...he have error in simplify mesh..
..but Terranim8or is very powerfull for particles and special effects, etc..!  :D
in future are good..if..anim8or has this.... :'(
sorry my english...
 neirao - Brazil
ViVie
« Reply #4 on: November 01, 2008, 08:49:24 am »
I'll be very insterested in a script that works :)
odp04y
« Reply #5 on: November 01, 2008, 11:35:30 am »
Would it be possible for somebody to alter NickE's untrianglation script to do this. (change 4 quads into one larger quad)?
« Reply #6 on: November 01, 2008, 05:05:35 pm »
Kubajzz  has maker this script,download in:
http://www.anim8or.com/smf/index.php?topic=1105.msg9368#msg9368
att.
Neirao
« Reply #7 on: November 02, 2008, 02:27:10 pm »
Yes, that script Neirao suggested is good for poly reduction... The problem is that it's not able to simplify an arbitrary mesh, it can only work with a mesh created by subdivision algorithm.
I've been working on a general poly reducer for a while and it's already finished, but the script execution takes several hours if the mesh has more than 2000 polys... I guess the algorithm needs some kind of optimalization ::) I hope to post it soon, stay tuned...
« Last Edit: November 02, 2008, 02:35:19 pm by Kubajzz »
« Reply #8 on: November 09, 2008, 08:29:43 am »
It's here!
I just released a poly reducer plugin, check it out:
http://www.anim8or.com/smf/index.php?topic=1105.msg11651#msg11651
It's not perfect, but I believe it may help some of you...
