Pages: 1 [2]
Author Topic: Script Request: untriangulate faces  (Read 36784 times)
benzjie
Re: Script Request: untriangulate faces
« Reply #15 on: February 07, 2009, 04:43:54 am »
a:  it may take a while
b: you have to make a new attribute called tolerance.
gattispilot
« Reply #16 on: February 18, 2010, 11:16:47 am »
I get this error:
Error on line 44: undefined indentifer 'attribute'
error on line 44: ';' expected
« Reply #17 on: February 18, 2010, 04:58:22 pm »
How do i... USE a script file? It makes absolutely no sense to me at all.
« Reply #18 on: February 18, 2010, 08:37:41 pm »
First, read the "Installing plug-ins" section on the Scripts page.
Once you install a script, re-start Anim8or. If the newly installed script is a "Command plug-in" (such as the Untriangulate Faces), there will be a new item in the "Scripts" menu. When you install a parametric-mesh plugin, a new button will appear in the left panel in Object mode and when you install an export plugin, a new option appears in the "Export" dialog box... That's it :)
Jdez
    • Tech Blog
« Reply #19 on: February 22, 2010, 04:16:49 am »
gattispilot: are you using version 0.97 preview? 0.95 doesn't support attributes.
Having fun with ASL!
Pages: 1 [2]
