Author Topic: what am i doing wrong? (bind mod)  (Read 14299 times)
Shasaar
« on: August 07, 2008, 08:37:44 am »
Hello,
i'm a new user to anim8or and was working with the beginner tutorials and tried to make a flower.
My main problem now is, that i'm not able to use the modifier in a way it should work, cause only the modifier does what i want it to do, but not the mesh bond to it.
I recorded a small (5mb) vid, how i use the modifier and the steps i'm doing.
It's available here: http://www.palazzo-mondo.de/files/bind_mod.avi
Could somebody tell me pls what i'm doing wrong and how i'm able to use it?
Thanks in advance for any help.
Shasaar
Re: what am i doing wrong? (bind mod)
« Reply #1 on: August 07, 2008, 10:47:02 am »
hey, make sure then the ball is in "Center of Modifier".
if this is far don´t work.
see this in Top window, ok!
Neirão - Brazil
« Last Edit: August 07, 2008, 10:54:01 am by neirao »
MP3D
« Reply #2 on: August 07, 2008, 07:23:54 pm »
Half way down the page is the answer to your troubles.
http://www.mp3d.info/Anim8ortutorials/page1.html
Have fun. ;D
MP3D
Shasaar
« Reply #3 on: August 09, 2008, 06:54:54 am »
Hello,
@neirao: Thanks a lot, that was my fault and i didnt noticed it :D, cause i used always the predefined views (front, left etc.) and didnt turn the view to see if the modifier is above the mesh :D, i thought the modifier will "warp" to the mesh automatically, when i click "Bind Modifier".
@mp3d: the tutorials didnt give me the answer to my question :D, i did some of em so far (flower, tires, bowl) and they are really great and helpful to learn the use of anim8or.
I was doing the tutorials when i got that problem :).
Btw., thanks to Steven Glanville for such a great program! I'm still wondering how it's possible that it's less than 2 MB :D.
I guess that's what someone can call a very clean and proper coding.
Cheers
Shasaar
« Reply #4 on: August 09, 2008, 08:42:57 am »
Exactly my point of view. There is no point in buying a powerfull computer and then stuff it with bloated software ;D
MP3D
« Reply #5 on: August 10, 2008, 11:50:28 am »
@mp3d: the tutorials didnt give me the answer to my question Cheesy, i did some of em so far (flower, tires, bowl) and they are really great and helpful to learn the use of anim8or.
I was doing the tutorials when i got that problem Smiley.
In the video tutorial on the warp modifier, I specifically tell the viewer to make sure the object is in the warp modifier. I also show the viewer that the modifier can be moved and scaled. Could you explain what part you had trouble on so I can make sure my tutorial is not miss leading/ confusing so no one else runs into this problem.
Thanks.
MP3D
