Author Topic: Animating  (Read 14979 times)
Kiji8989
Animating
« on: August 04, 2008, 11:20:46 am »
I have my model skinned and rigged, but when I try to animate it, none of the bones move...help?
Aarangend
Re: Animating
« Reply #1 on: August 04, 2008, 02:55:34 pm »
once you have all the bones in aligned with the body go to figure and click on the "Multi-Bone SKin" button (The one that looks like a "Y"... Well in my opinion it looks like a "Y")... then you can either do Weights or Bone Influences... Personally I like Weights better... I am not quite sure how bone influences works though
But anyway... When you have Weights picked out you just select a bone and paint the area that you want that bone to move (For instanst if you want a bone to only move a forearm, then you paint the area of the forearm)
Hope that helps... If that is your problem
Re: Animating
« Reply #2 on: August 04, 2008, 08:36:45 pm »
Aarangend: S/he said it was already rigged.
Kiji8989: Have you added joint limits to your bones in figure mode?
Try the Walk tutorial for more info (you might just want to skip to the figure editor part).
http://anim8or.com/tutorials/simplewalk/index.html
SirBonovox
Re: Animating
« Reply #3 on: August 05, 2008, 11:10:51 am »
Did you make sure the Keyframe button was green?  It must be green or it won't save keyframes in the timeline.
Kiji8989
Re: Animating
« Reply #4 on: August 05, 2008, 03:43:28 pm »
ok, I added bone limits and didnt save afterward...oops. XD Ok, next question. Is there a way, so that when I paint a leg the weight brush, it doesnt go to the other leg?
Re: Animating
« Reply #5 on: August 05, 2008, 04:05:03 pm »
View your figure in Perspective and move and rotate it so that there are no other limbs close to it or behind it, then paint.
Kiji8989
Re: Animating
« Reply #6 on: August 05, 2008, 04:23:45 pm »
Thats the thing...I'm doing a bear, and the limbs are HUGE. So, Its like, impossible to do that...
SirBonovox
Re: Animating
« Reply #7 on: August 05, 2008, 09:14:16 pm »
When you use weight paints it only paints the vertices (points).  You have to rotate the model so that you paint the point you want and not the one behind it.  Switch to wireframe view and zoom in close so you can see which point you are clicking on when you paint. ;)
goby55
Re: Animating
« Reply #8 on: August 08, 2008, 01:45:42 pm »
i cant move the bone xy and z i have to chose 1
MP3D
Re: Animating
« Reply #9 on: August 08, 2008, 03:27:14 pm »
http://www.mp3d.info/Anim8ortutorials/page2.html
take a look at the first tutorial.......................>>>>>>>
MP3D
