Author Topic: Mirror help  (Read 8528 times)
Mirror help
« on: August 03, 2008, 04:29:08 pm »
Im making a body right now and im using the mirror tool. im having a problem with a crease down the middle. the x axis of the points goin down the middle r at 0.00. when i mirror, then subdivide. there is a crease down the middle. im woundering if im modeling this wrong. please give me a tip.
karate5662
    • my mini city
Re: Mirror help
« Reply #1 on: August 03, 2008, 05:00:19 pm »
did you merge the points along the crease? it doesn't look like it.
Re: Mirror help
« Reply #2 on: August 03, 2008, 05:10:54 pm »
im not sure what u mean. when u mirror it it creates a seperate object. and im not sure how 2 connect 1 edge to another with to seperate objects. ive tried grouping and a few other things. ill try and mess with it to c if i can merge points.
Re: Mirror help
« Reply #3 on: August 04, 2008, 04:43:15 am »
What you have to do is select the two halves you made (make sure it's a mesh.  If it isn't, double click the subdivision object, change the "working" section to '0' and press ok.  You should have the original mesh, then go "build>convert to mesh".)  Now you want to select the two halves and go "build>Join solids".  They're now one mesh.  Then select with the drag select tool the column of points down the middle of the model that need to be merged and go "edit>Merge points" and put something small in like 0.1 since you said they're all at 0.0.  The points should then be merged and you can make it a subdivision object.
Re: Mirror help
« Reply #4 on: August 04, 2008, 01:17:41 pm »
thanks dude i think i got it
