Author Topic: Bug in chain maker (script)  (Read 18684 times)
Paulo
  • Love 3D !
    • Paulo's web site : 3D art with Anim8or
« on: August 01, 2008, 08:20:32 pm »
The script Chain Maker which is in the the official selection (http://anim8or.com/scripts/index.html) don't run. My Anim8or said : bug on line 105  :-X
What a pity, I found this script very interesting !
Paulo, French 3D Maker
My VRML exporter for anim8or : http://www.anim8or.com/smf/index.php?topic=3168.0
NickE
Re: Bug in chain maker (script)
« Reply #1 on: August 01, 2008, 10:43:37 pm »
Were you using version of 0.97b of Anim8or?  Were you using the command version or the parametric version?  Did you name the path "chainpath"?
« Last Edit: August 01, 2008, 10:47:48 pm by NickE »
Jo3L09
« Reply #2 on: August 06, 2008, 02:34:53 am »
I have the same problem that Paulo here =(
I used both versions (command and parametric), i renamed the path as "chainpath", and i have the 0.97b version but nothing happen... i still have "error on line 105" message...
Please help!!!
NickE
« Reply #3 on: August 06, 2008, 07:04:32 pm »
I have been unable to replicate your error.  It is possible that the instructions for use were not complete.  Please try the following tutorial and report back your results:
http://www.tranceportsoftware.com/anim8orstuff/chainmakertutorial.htm
Jo3L09
« Reply #4 on: September 11, 2008, 04:32:53 am »
thanks for the tutorial but i can't load or run the script... i think that's what the "error on line 105" message is trying to say hehe
« Reply #5 on: September 11, 2008, 04:40:39 am »
What exactly does the error message say? There should be something more than "Error on line 105"
Jo3L09
« Reply #6 on: September 28, 2008, 03:40:42 am »
Compiling "C:\Documents and Settings\.........\Anim8or\Scripts\chain_maker.a8s":
error on line 105: undefined member reference 'GetNumSplines'
error on line 105: ';' expected
error on line 105: incompatible types in assignment
error on line 105: '}' expected
105 lines 5 errors
This is what the message says
NickE
« Reply #7 on: September 28, 2008, 01:42:51 pm »
You get that error if you use any version of Animator before 0.97b.  This script ONLY works with version 0.97b and later.
